How to count the number of cars in same NodeNetwork ?
Lion1989x
Message 1 of 9
Lion1989x
[ FlexSim 18.0.10 ]
How do you count the number of cars that collide on a spot? And how to solve the problem of not allowing cars to run over the spot?
This is my file.
Lion1.fsm
Replies (8)
Message 2 of 9
jason_lightfoot_adsk
Use zones, lists or resources to restrict access. In the case of zones you can easily find the current content.
Message 3 of 9
Lion1989x
Can your show example a little to me please ? I ' m never to used. "Use zones, lists or resources to restrict access"
Message 4 of 9
They're in the documentation and tutorials: Zone, Lists, Resources
Message 5 of 9
Lion1989x
Please Example a litte to me T T .
002.fsm
Message 6 of 9
A token will wait at an EnterZone activity if the zone is configured to restrict the number of tokens and it has reached capacity. The waiting token will continue once another token has reached a corresponding Exit Zone activity and freed up some capacity. Often its a good idea to practice configuring this in a small test model to check you understand its operation before applying it to your model.
Message 7 of 9
Lion1989x
It's close to being right here. Where do I need to set more? 1 point allows only 1 car to enter.
3.fsm
Message 8 of 9
Lion1989x
I got it by Resource. when i want to know statistics must to using zone ?
NetworkNode - Fix Resource
4.fsm
Message 9 of 9
You can access the number of tokens that have acquired resources using the activity's statistics:
getstat(getactivity("ProcessFlow", "Resource"), "Content", STAT_CURRENT, current)
