How to connect parallel or perpendicular conveyors?
shoog_n
shoog_n
[ FlexSim 22.2.0 ]
I am facing a problem when connecting two conveyor segments with each other, one is perpendicular to the other. Or in case I have an angle between them. The side wall or the skirt does not disappear. I attached two snipping shots for illustration! FL1.JPGfl2.jpg
carter-walch
Hi @Shoog N,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators.
Also, have you tried using both the Join Conveyors tool and manually connecting the conveyors like this?
shoog_n
I do it like this, but it does not work for some reason. I attached a small part of the model in this reply. Can you please check it and let me know! ThanksTesting Example.fsm
jason_lightfoot_adsk
You probably need to make sure the 'rise' variable is zero on the connecting conveyors.
You can try running this script which will set the value to zero for all conveyors where the rise is less that the riseThreshold local variable:
Array convs=Table.query("SELECT ARRAY_AGG(Object) FROM Objects() WHERE 'Conveyor::Conveyor' IN Classes")[1][1];
double riseThreshold=0.1; //  change this to a value that retains your conveyors with gradient
Object conv=NULL;
while (convs.length){
    conv=convs.pop();
    if (Math.fabs(getvarnum(conv,"rise"))<riseThreshold)
        setvarnum(conv,"rise",0);
natalie_white
Hi @Shoog N, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
