How to configure the output and input ports of a processor to a queue?
Richie21
Richie21
[ FlexSim 23.1.3 ]
Hello, I don't quite understand how opening and closing ports works. In this case, I have my 5 processors and my 5 queues. What I want to do is if the processor already generates 10 boxes in a Queue, the output port of the processor is closed until that the Queue is completely emptied, reopen and continue generating the boxes, could you please help me1692262844554.png
carter-walch
Hi @RicardoMtz ,
portsDemo.fsm
Here is a demo model of using triggers in the Queue to close and open ports on a separator. You can apply this logic to any trigger to get the logic you want. In this example, When the content (current.subnodes.length) of the queue increases to 10, the input port of the separator is closed. You can tell a port is closed when there is a red line on the port:
Notice the red line next to the green port. This means closed
When the content of the queue decreases back to 0, the input port is opened and a new flow item enters the separator. This logic will repeat throughout the model run
Hope this helps!
julie_weller
Hi @RicardoMtz, was Carter Walch's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
