Array.append(int) in for loop, appends NULL values instead. User error or bug?
cphilpottX22K5
cphilpottX22K5
[ FlexSim 23.1.2 ]
There is code in the assign labels area of my Source (in the arrivals tab) that assigns a patient type to tokens. (The label named type) I think the logic for selecting the type works fine, but I can't append an integer to an array for some reason and that's messing everything up.
Posting my model. Here's what it looks like. In the same loop I append to another array and that one works as expected. I am printing the values before and after each append and something here is just not working as expected.
Any help?
GSH_model_0-0-18-2_destroyedForTechSupport.fsm
HERE'S AN EXAMPLE OF THE OUTPUT CONSOLE:
flowStopsX as empty array:
Array[0]: {}
flowStopsPct as empty array:
Array[0]: {}
Loop number & value to append to flowStopsX:
1
flowStopsX with appended value:
Array[1]: {NULL}
flowStopsPct with appended value:
Array[1]: {41.65}
2
Array[3]: {NULL,NULL,NULL}
Array[2]: {41.65,41.08}
7
Array[10]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[3]: {41.65,41.08,4.80}
8
Array[18]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[4]: {41.65,41.08,4.80,1.92}
9
Array[27]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[5]: {41.65,41.08,4.80,1.92,1.92}
10
Array[37]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[6]: {41.65,41.08,4.80,1.92,1.92,0.96}
11
Array[48]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[7]: {41.65,41.08,4.80,1.92,1.92,0.96,0.96}
12
Array[60]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[8]: {41.65,41.08,4.80,1.92,1.92,0.96,0.96,0.96}
13
Array[73]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[9]: {41.65,41.08,4.80,1.92,1.92,0.96,0.96,0.96,0.96}
14
Array[87]: {NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL}
Array[10]: {41.65,41.08,4.80,1.92,1.92,0.96,0.96,0.96,0.96,4.80}
flowStopsPct as modified list of ranges:
Array[10]: {41.65,82.74,87.53,89.45,91.37,92.33,93.29,94.25,95.20,100}
END OF SCRIPT FOR THIS TOKEN
cphilpottX22K5
Answered my own question...
I should be using Array.push for an integer or double.
Array.append appends another array.
