How to assign combiner to different references using Process Flow
JoseJ
JoseJ
[ FlexSim 22.1.4 ]
Using Process Flow, we have a BOM with different raw materials (source) and through combiners (queues with combiner function) we do different assemblies creating a new reference. Each combiner is going to act as more than one assembly table depending on its capacity (Max content). Our goal is to assign a specific number of assembly tables (combiners) for the assembly of each reference, because each reference has a different process time. However we do not know how to do it.
For example, we need 4 assembly tables to do reference "M" with a process time of 6.5h and 2 assembly tables for reference "N" with a process time of 8.25h.
There goes our model if you want to check it out, thank you.
OTRO MODO.fsm
FelixMoehlmann
If each combiner only works on one product, couldn't you just use the default Combiner object with a static components table?
With what you have currently build, you could use a Zone or Resource activity to limit how many tokens can enter the assembly process (Delay block) at any time.
A Resource has the benefit that it can be tied to a 3d object, if you want to phyically move the items into separate "assembly tables". A zone would be entirely 'virtual'.
Jeanette_Fullmer
Hi @José Juan Ramírez Gutiérrez, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
