How to access tracked variable statistics in code
craig_dickson
craig_dickson
[ FlexSim 16.2.2 ]
I am using tracked variables to gather statistics in my model. One is of type Level, used to count the number of pieces moved; the second is of type Time series.
I would like to access the Min/Avg/Max values in code using getstat(), similar to how I can with any PF Activity, e.g., getstat(trackedvariable("vPiecesReplenished"),"Content", STAT_CURRENT);
However this returns 3.4E38 (i.e., unknown value).
(For a PF activity I use getstat(getactivity("ProcessFlow", sActivity), sStatistic, STAT_CURRENT)
I'm guessing that "Content" is not the right statistic name? What names should I use, or is there a different command? Or is it possible at all?
Craig
Jacob_Gillespie
Give an empty string as the name:
getstat(trackedvariable("vPiecesReplenished"),"", STAT_CURRENT);
Normally you have to specify which statistic you want from the given object, but a tracked variable is the statistic.
craig_dickson
Thanks. I like easy answers 😉
matt_long
Starting in FlexSim 2017 Update 1 you can use the TrackedVariable class. Then the code is even simpler:
TrackedVariable("vPiecesReplenished").value //Current value
The TrackedVariable class also includes methods for getting the average, maximum, minimum, etc.
