How to accelerate delays by assigning one more staff
kim_j6
Message 1 of 8
kim_j6
[ FlexSim 23.1.1 ]
ex2.fsm
Hello.
Before I ask you questions, I would like to thank you again for always helping me. Thank you very much.
The example model that I've uploaded is
Staff will move to the bed where the nearest patient lies, wait for 90 seconds, and then move to the nearest floor spot.
+ At this time, one surplus staff occurs.
I have a question in the process.
To sum up the question,
1. I'd like to add up to one more staff to a bed that already has a staff in charge.
2. If there are two staff members, I would like to reduce the remaining time by 1/3 and send it to Floor spot.
Thank you.
Jerry.
Replies (7)
Message 2 of 8
jason_lightfoot_adsk
Are you aware of the exceptions your model is throwing? We prefer to look at models without exceptions unless they are the topic of the question specifically. The reason is that by fixing the exceptions the user may actually find, understand and fix the reason the model is not working as intended.
Furthermore a model without exceptions allows us to focus on the question being asked rather than being sidetracked by other problems the model has which may be both obvious and indicate a lack of care and attention to the model detail and its operation.
Message 3 of 8
kim_j6
That's a thought-provoking answer. Thank you very much.
Message 4 of 8
Jeanette_Fullmer
Have you been able to sort out the exceptions in your model? If so and you still have this question can you repost your model?
Message 5 of 8
kim_j6
The example model has been modified and re-uploaded. Thank you.
Message 6 of 8
julie_weller
Did fixing the exceptions solve your problem or do you still need help with your original question?
Message 7 of 8
kim_j6
Some progress has been made, but the underlying problem remains unresolved.
Message 8 of 8
Let's close this post as you have a second question here.
