How do I set AGV speed in my simulation?
hh_2105
hh_2105
[ FlexSim 21.0.10 ]
Hi help needed! I tried changing the speed in my Simulation but not able to do so?
1722408769273.png1722408802566.pngSim Model
jason_lightfoot_adsk
For AGVs you set the speed parameters in the AGV Network properties based on path class, agvtype and loadtype - shown in your first image. The AGVs properties are therefore greyed as they are not used in this case.
hh_2105
for this method is there a guide in flexsim or a simple simulation that i could try and follow as i tried changing the parameters in the first pictiure but the speed still do not change.
Make sure you apply the changes. Create a small test model and upload that if you can't get it to work.
hh_2105
Okay will do thank you, by the way it may not have work due to misunderstanding of the units used, what is the units used for the first picture and how may i know it?
It will be whatever your model is set to in terms of distance units and time units.
