How do I resume item on message trigger?
jonathan_s3
Message 1 of 10
jonathan_s3
[ FlexSim 20.2.3 ]
Using either a decision point or a conveyor station, how do I resume item on message trigger without process flow?
Replies (9)
Message 2 of 10
jason_lightfoot_adsk
I might pass in the item to resume as the sending object. The question then is which object is receiving the message, and from where is it sent?
Message 3 of 10
Here's an example using the DP arrival (to stop and send a delayed message) and DP messagetrigger to resume.
DPstopMessageResume.fsm
Message 4 of 10
jonathan_s3
In your example the decision point is sending the message to itself. So
conveyor.itemData[fromObject].resume();
resolves correctly. But if another object is sending the message then it does not. I get:
time: 4.958494 exception: FlexScript exception: MODEL:/Pos1>variables/Custom/onMessage
In another thread the reply used some kind of label on the object to point to the flow item. But I can't figure out how to do that. Here's that thread:
https://answers.flexsim.com/questions/40783/code-to-resume-conveyor.html
Why aren't there more pick list options for on message triggers? It seems like it would be incredibly useful.
Message 5 of 10
Here's an example where the top conveyor's DP sends a message to the lower DP (centerObjects reference).
The lower DP ignores it if it doesn't have an item - which I set as a label on arrival and clear on message.remoteDPmessageResume.fsm
Message 6 of 10
jonathan_s3
I think I figured it out. On arrival I have a code snippet:
current.OtherItem = item
Where "OtherItem" is a pointer label I created on my station.
Then on message can resume the item using that pointer label to the item.
I created the resume code first as an on Arrival trigger then copy/paste the code from there to the on message trigger code.
Object fromObject = param(1);
double msgparam1 = param(2);
double msgparam2 = param(3);
double msgparam3 = param(4);
Conveyor.DecisionPoint current = param(9);
Conveyor conveyor = param(10);
{ //************* PickOption Start *************\\
/***popup:Conveyor_StopResumeItem*/
/***tag:description*//**Resume Item*/
if (/**\nCondition: *//***tag:condition*//**/true/**/) {
Object involved = /** \nItem: *//***tag:item*//**/current.OtherItem/**/;
involved.up.as(Conveyor).itemData[involved].resume();
} //******* PickOption End *******\\
This forces a resume item pick option in the on message trigger to show up.
With this method I really only wrote one line of code by hand. It was just figuring out where all the pieces needed to go after that. Seems to work so far.
Message 7 of 10
Is this all related the that 4 station workcenter with the trays that return underneath or is it something new?
Message 8 of 10
jonathan_s3
Yes and no. It was something that was frustrating me so I had to figure it out. I will use it for that model.
I can't for the life of me understand or replicate the process flow you wrote that worked for that model.
Message 9 of 10
We can do a zoom meeting if you want to go through it and I can explain everything.
Message 10 of 10
jonathan_s3
Next week sometime sure.
