How do I get two forklifts to work together?
pastra_T
pastra_T
[ FlexSim 22.2.4 ]
1-4-22Before_autosave.fsmFrom the attached model There is 1 working forklift. I want 2 forklifts to work together.
Jeanette_Fullmer
Hello @pastra.T,
It would work best if you split your process flow into two flows. One for the items and one for the transporters. I use a list to push the items that have been assigned for the order and the transporters pick an item off the list. The transporters pick items till they are at capacity or there is not an item of the same order number to pick up. They then will unload their items and cycle through the process again.
1-4-22before-autosave_1.fsm
pastra_T
Thank you so much and What if I want the forklift to be responsible for each order separately?
pastra_T
Each order picks up products with different quantities and locations.
Jeanette_Fullmer
Hello @pastra.T, Then you will want to assign the transporters with their order ID before they pull their first item and increment through the orders when it loops. You could assign Transporter 1 with order ID 1 and Transporter 2 with order ID 2 and then increment by 2 when it loops.
