How do I get my missing tabs back? (Default Workspace doesn't work)
aaron_c
aaron_c
[ FlexSim 19.1.2 ]
So I experienced an issue where my console, local variable, and script tabs were showing the incorrect data (i.e., the script tab content was showing inside the output console, and other weirdness like that). So I thought, no problem, I'll close them and reopen them, that will probably fix it. I closed all of my bottom tabs. I went to the Debug toolbar option, and went to reopen the views, BUT, they all show the blue box around them, indicating they're already open. I click them and nothing happens. So then I thought to use the Default Workspace option, but when I click THAT, FlexSim goes into a Not Responding state....Is there an alternate method to get those tabs back? I really don't want to recreate this model, but I can't continue without being able to at LEAST watch my variables...
zac_h_adsk
Could you please post your model or something similar such as pictures that demonstrates your problem. Proprietary models can be posted as a private question for FlexSim U.S. support only.
Ben_WilsonADSK
Hi @aaron.c,
You may want to update your graphics drivers, or try some of the other suggestions in this article:
https://answers.flexsim.com/articles/11/view.html
Ben_WilsonADSK
Hi @aaron.c,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back from you in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case. You can always comment back at any time to reopen.
__ANON_USER__1
Closing outdated question
