How do I get item dwell time with data collectors
tee_hiett
tee_hiett
[ FlexSim HC 5.3.4 ]
I have a pharmacy represented by the three item objects shown on the attached jpg file. I want to collect the dwell time for item objects Pharm_In and Pharmacy. I have tried to do this with data collectors without any success. I cannot find any help on this forum.
Suggestions??
Tee
isaac_l1
@Tee Hiett
In the Dashboard you can add a Composite Staytime chart/graph. Then you can use the eyedropper to select the item going in and out. Another option is you can set a specific group of items going in and out of your process by using the add button next to the eyedropper, but you have to make sure to make a group with your items first. Let me know if this is what you are looking for.
tee_hiett
Thanks, Isaac. Where is the Composite Staytime chart/graph in FlexSim HC?
Tee
cliff_king
You don't need a Data Collector, because "Dwell Time" for Item Objects is a standard dashboard widget. Here's an example model using this dashboard.
dwell-time-of-item-objects.fsm
emily_hardySTLSK
Apologies, this answer was for the standard FlexSim. Check out the answer below for a HC solution!
dmdurbinMDA
@Cliff King, to expand on this, how would I get the length of stay an item was in the model (created until it exited or reached a certain point)? The only way I can think of is using a data collector but I'm not entirely sure how that process would work regarding items.
joerg_vogel_HsH
@doug.durbin, this would be a nice new question, don’t you think?
Otherwise look into command manual for getcreationtime.
