How create a change time tool between each of my item in my existing model ?
remi_a2
remi_a2
[ FlexSim 21.2.2 ]
Hello, In fact I already have a function in my setup time which returns to a global table but I don't know if I can put 2, a "use global table" function and an "if item label value change" function.
test1-fm (4).fsm
clair_augsburgerZGWRZ
Hello Rémi,
You can use the If Item's Label Value Changes pickoption, and in the field If Item's Label Changed you add a statement to read in a Global Table.
In the attached example 2021-10-22 Changeover time.fsm , I randomly create 3 product types and the change over times are:
The setup time is defined as follows:
In the State Gantt chart, you can check that there is a setup time every time the product type changes:
Hope this helps.
remi_a2
Ok I understand for this part, but now how can I assign a setup time to each item?
I think I misunderstood your question. Do you mean that you want to be able to define 3 steps as below:
  1. a changeover time (only if the product type changes)
  2. then a setup time (for each item)
  3. and a process time (for each item)
remi_a2
Yes exactly
So you can use a MultiProcessor (https://docs.flexsim.com/en/21.2/Reference/3DObjects/FixedResources/MultiProcessor/) instead of a Processor. On a MultiProcessor, you can add as many steps as you want. Here is an example: 2021-10-22 Changeover + Setup + Process.fsm.
remi_a2
Perfect thanks a lot
