How can use task executers together for one process ?
mehmet_ul
mehmet_ul
[ FlexSim 18.2.2 ]
I have 4 combiners and 2 basic task executors as robot. I wanna to use these executors like that when combiner 1,combiner 2 and combiner 4 are processing,TE1 will interest in combiner 1 and combiner 2, TE2 will interest in combiner 4. When these proseses are finish TE 1 and TE 2 will interest in combiner 3 together. How can solve this situation ? Thanks for your attention.
tanner_p
Could you clarify what the task executors will be doing when they are "interested" in the combiners? Will they be animated in any way?
If you could upload an example model, it would help us to see what you'd like to have happen. If your model contains proprietary information, you can upload the model and question to a private post.
mehmet_ul
deneme.fsm
I wanna two operator work together for combiner 3 for process at the same time.
sebastian_hemmannE3JAU
Hi @Joshua S, I´m not sure if I misunderstood something, but there is a quiet easy way to make 2 operators perform in one Process Task in the 3D Objects:
and in this way the operators are also both bound to the process and not only walked to the machine!
15285-15283-deneme-1.fsm
joshua_s
@Mehmet UL
Take a look at this answer by @sebastian.hemmann
