How can use task executers together for one process ?
mehmet_ul
不适用
22 次查看
4 条回复
1 条消息(共 5 条)
mehmet_ul
不适用
[ FlexSim 18.2.2 ]
I have 4 combiners and 2 basic task executors as robot. I wanna to use these executors like that when combiner 1,combiner 2 and combiner 4 are processing,TE1 will interest in combiner 1 and combiner 2, TE2 will interest in combiner 4. When these proseses are finish TE 1 and TE 2 will interest in combiner 3 together. How can solve this situation ? Thanks for your attention.
0 个赞
已接受的解答 (1)
23 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
tanner_p
不适用
Could you clarify what the task executors will be doing when they are "interested" in the combiners? Will they be animated in any way?
If you could upload an example model, it would help us to see what you'd like to have happen. If your model contains proprietary information, you can upload the model and question to a private post.
0 个赞
3 条消息(共 5 条)
mehmet_ul
不适用
deneme.fsm
I wanna two operator work together for combiner 3 for process at the same time.
0 个赞
4 条消息(共 5 条)
sebastian_hemmannE3JAU
已接受的解答
Hi @Joshua S, I´m not sure if I misunderstood something, but there is a quiet easy way to make 2 operators perform in one Process Task in the 3D Objects:
and in this way the operators are also both bound to the process and not only walked to the machine!
15285-15283-deneme-1.fsm
5 条消息(共 5 条)
joshua_s
不适用
@Mehmet UL
Take a look at this answer by @sebastian.hemmann
