How can I unload items from a pallet that is on an AGV using operators?
luca_bh
luca_bh
[ FlexSim 21.2.4 ]
Hi everybody 🙂
I'm relatively new to flexsim. I struggling with a couple of steps that are part of a larger model.
Anyway, I am supposed to do the following:
1. AGV picks up a pallet with 8 boxes stacked on it. (simple)
2. AGV travels to CP where it waits until two operators unload only the boxes into a queue.
3. It then travels to another location where the empty pallet is put in another queue.
4. AGV returns to 1. (easy)
I struggle mainly with steps 2 & 3. In my model, the operator always picks up the pallet + the 8 boxes still stacked on top. I am using a mix of 3d and process flow for my model but I want to do these steps in a process flow and without a separator.
I couldn't find any solution on this site so far and thought that I would try my luck.
I am thankful for any tips or help!
task_practice_v2.fsm
jason_lightfootVL7B4
Your label items is just the pallet so I would instead label it as 'pallet' on the token.
Then you should push this to the unload list:
token.pallet.subnodes.toArray()
Model attached.
task-practice-v2_jl.fsm
luca_bh
Thanks, Jason! But how come it pushes now only 4 tokens to the list despite there being 8 boxes? I can't find where it groups the boxes into one item.
In theory, the 8 boxes created in the beginning should all be pushed into the array with the subnodes command right?
luca_bh
never mind, I found it! Thanks!!
12345bjy
@Jason Lightfoot
Hello!I practice this model I meet some problems and this model is reporting an error
Can you help me see where I went wrong?And I also have some questions are not clear,
Can you help me? Thank you!
1、What is the purpose of this label?
2、Usually,reporting the error should how to handle?
怎么让operator仅卸载AGV上的托盘上的box.fsm
moehlmann_fe
You need to properly refer to the item that is to be loaded. (Same in the unload Run Sub Flow activity)
___operator___agv______box_1.fsm
12345bjy
@Felix Möhlmann
Based on your reminder I know the key logical points,then I correct them.At the same time, I also understand why this change was made.
But,I still findTwo questions:
1、Reporting an error about Push item to list,Why ?
2、I seting the operator loads the request number is 2,why the two people loads 4?
