How can I set up conditional rule using FlexScript
hsiangchao
hsiangchao
[ FlexSim 22.2.2 ]
I have lots of AGV straight paths.Some of paths conditional rule are rule1, others are rule2. How can I set up conditional rule using FlexScript. Thank's.
moehlmann_fe
What exactly do you mean by "set up" a rule? Creating a new rule, assigning an existing rule to paths or use custom code to create a more complex rule than checking a label?
To assign an existing rule to a path you can use the following code: This example assigns "Rule 1" to "StraightPath1".
Object Path = Model.find("AGVNetwork/StraightPath1");
treenode rule = Model.find("AGVNetwork>variables/pathConditions/Rule 1");
Path.find(">variables/condition").value = rule;
