How can I set my source that it will create an item every 15 seconds?
nicole_s2
nicole_s2
[ FlexSim 19.0.0 ]
Hi all,
I want to built the following model with this kind of settings: Soure-> Processor 1-> Processor 2 -> Sink. The duration of one shift is 480 min - 45 min (break) = 435 min (21600 seconds).
The source should create every 15 seconds a product. I know that I can use the scheduled sequence in the source to generate this but I do not know how to make it. The Processor 1 has a process time of 70 seconds, the processor 2 a process time of 60 seconds. My factory has to produce 320 items within one shift. How can I reach this?
Thank you very much!
jeff_nordgren
@Nicole S2
Is it possible for you to send us your model or a sample model of what needs to happen? It's hard to give you a specific answer to your question when we don't know what your model is doing.
Thanks.
Jacob_Gillespie
Creating an item every 15 seconds can be done with just an Inter-Arrivaltime.
Set the Inter-Arrivaltime to 15 instead of a distribution.
isaac_l1
Hi @Nicole S2
Does Jacob's reply above answer your question? If so, please click the Accept button below the answer. Let us know if you have any more questions.
Thank you!
