How can I request a resource in the processflow by name or ID?
enrique.elizaga
enrique.elizaga
[ FlexSim 18.2.2 ]
Im working on a model that uses process flow resources. The reference is an array. Line 1, Line 2, Line3. Can I call and use a resource that matches a label.
token.LINE == resource reference or name
4 = Line4
Currently it just requests whatever resource is available: 4 is assigned Line2
joshua_s
To do this you need to go into the advance settings of your Resource activity. The pictures below show the difference items to change, then you can request the specific line based on the name, or the token label.
jeff_nordgren
@Enrique Elizaga
Could you send in your model or a sample model of the problem?
Thanks.
