How can I get the Exit transfer reference from the conveyor using code?
paula_carneiro_martins
[ FlexSim 19.0.2 ]
In a conveyor has a lot of conveyor points.
I have the conveyor reference and I need to get the reference/name of the exit transfer, without centerport.
Is that possible?
joshua_s
using
getvarnode(Model.find("Conveyor1"), "conveyorPoints").subnodes[1].value.up.up.up
will reference the exit transfer object
joerg_vogel_HsH
@Joshua S, I think you can get the object easier with "ownerobject" instead of the relative path "up.up.up".
Object convPoint1 = ownerobject(getvarnode(Model.find("Conveyor1"), "conveyorPoints").subnodes[1].value);
joshua_s
@Jörg Vogel
Thank you, that is a much cleaner approach.
jason_lightfoot_adsk
The conveyorPoints node contains photoeyes, decision points, stations and other objects. To find transfers see this post.
