How can I change the default patient walking animation?
ALibreros
ALibreros
[ FlexSim 22.2.3 ]
Hello, I need to change the animation when walking for a percentage of the patients that enter the system. In other words, according to a label, some patients will have the animation by default and others the animation of walking injured. How can I achieve this? Thank you very much for the help.
jason_lightfoot_adsk
setProperty("WalkAnimation","WalkInjured")
ALibreros
Thank you!!
Note that when you don't know the property name you can click the "Compare Properties" button and it will open the properties for that section in a table where the property names (for use in setProperty) can be seen, along with the current values.
Note for this to work with the people flowitems you must have instances in the model.
