[ FlexSim 18.1.2 ]
Hello all,
I'm trying to set item type through a label i created in the source with an arrival schedule. For some reason it's not taking the label value and keeps defaulting to 0.
The type will only work if I put a number there manually. I don't understand why the item type doesn't want to pickup the label of the same item
I'm setting the item type on creation trigger in the source.
The "Label" is the last column "BaleType"
and i'm using the "Set Item Type" to value item.BaleType
It's always defaulting to 0
Thank you for your time
Abdullah Abdullsalam
