Holding a batch on a conveyor while a separator is busy, then releasing it automatically
beatrice_lupi4
beatrice_lupi4
Hello everyone,
I have a question related to batch control and interaction between conveyors and a separator. I’ve attached the model.
Model logic
  • Two batches of items (each initially represented as a single object) are routed onto the same conveyor line.
  • The batches arrive sequentially at a Separator that processes one batch at a time.
  • The desired behavior is:
    • The first batch enters the Separator and is processed.
    • While the Separator is busy, the second batch must wait on the conveyor section immediately upstream (i.e. it should stop on the conveyor).
    • As soon as the Separator finishes processing the first batch and becomes available, the second batch should automatically resume its movement, reach the Separator, and be processed.
Current implementation
  • I am able to stop the second batch correctly:
    • On the Decision Point of the upstream conveyor, I use Stop Item on Arrival.
    • I check the state of the Separator (busy/blocked) and stop the batch if the Separator is occupied.
Problem
  • I am not able to restart the batch movement once the Separator becomes free.
  • In other words, the batch correctly stops when the Separator is busy, but it does not resume automatically when the Separator is released.
Question
  • What is the correct or recommended way to hold a batch on a conveyor while a downstream Separator is busy, and automatically release it when the Separator becomes available?
Any guidance or examples would be greatly appreciated.
Thanks!
zac_h_adsk
I would highly recommend learning and using process flow for a situation like this. The example attached uses process flow to achieve what you are looking for.
Also see this forum example, Example, for another process flow set-up.
