Hide red frame when object stopped
Paula_LG
Paula_LG
[ FlexSim 24.1.1 ]
Is there any way to hide the red frame that appears surrounding an object when it is manually stopped? I'm using the object.stop() command.
Thanks in advance!
jason_lightfootVL7B4
You can add onDraw code and return 1 to prevent the default drawing of the box. I think there are also some states that will not result in the box being drawn.
Paula_LG
Hi Jason,
Thank you for your answer!
I have already tried all available states and each one of them results in the box being drawn.
Could you tell me where would I have to add the onDraw code, please?
Add it to the On Draw trigger:
Paula_LG
Sorry, I thought you meant I had to add it to the object's tree. It works, thanks!
