help with PF
help with PF
ernesto_daniel_ag
help with PF
ernesto_daniel_ag
[ FlexSim 18.2.0 ]
hello all, I have a question about the function of my model, in the "bajar a descarga granalla" box, the activity that I assign is not done, even though the operator is no longer doing anything, it is still not activated , I attach my model thank you
I hope you can support me
bajar-a-descarga-granalla.fsm
sebastian_hemmannE3JAU
Hey @ernesto daniel AG,
the model you´ve attached doesn´t show this behavior for me.
You´ve made 3 stops in your code and one in your PF. If I erase this, your model is running without any warnings and it does work for me (no tokens stuck in activitys with Operators).
So could you please be more precise, what activity show at what time a problem?
ernesto_daniel_ag
Thank you for your attention, I found another way to do what I was looking for
isaac_l1
Hi @ernesto daniel AG
I'm glad you were able to solve your problem. Would you be able to post how you solved your problem as an Answer below? By answering the question you are helping the FlexSim community find solutions to similar problems they might also have.
Thank you!
