Healthcare Tutorial Question
jaidit_j
jaidit_j
[ FlexSim 21.2.4 ]
ER Model.fsm
Hey there, I'm trying to complete the healthcare tutorial model, and I got stuck in Step 6 "Assign Patient to Different Treatments". I followed and reviewed the steps, and I cant get get my patients to go to the X Ray Machine. They are only using the EKG machine. It looks like when I set the Label Set by Percentage in the Create Patient activity, it does not save it. It resets to 1 activity, 100%. I have made sure I don't miss a step. Something is wrong. thank you so much for your help! I attached my model.
Jeanette_Fullmer
Hello @Jaidit J,
The decide activity for some reason does not seem to be reading the patient label Treatment correctly. When I use the drop down options to select the label it write it like the following and that seems to work well.
Matthew_Gillespie
In the People Settings object the Treatment label has a space at the end of the name so its "Treatment " instead of "Treatment". If you remove the space from the end of that label name your model will work as expected.
Matthew Gillespie
FlexSim Software Developer
jaidit_j
@Matthew Gillespie thanks!! It works now!!!!
I appreciate it!
jaidit_j
Thanks Jeanette! it looks like there was a space after the "Treatment" word in the label, and that is why it didn't work. Now it works! I appreciate it!
