GUI refresh tracker
GUI refresh tracker
patryk_u2
GUI refresh tracker
patryk_u2
[ FlexSim 22.1.0 ]
Using Combobox in GUI I change rangemax to tracker but this change is visible only after closing and reopening GUI is it possible to refresh the tracker so that after changing rangemax GUI it will update. The same with the static text in GUI. Is it possible to change its name without closing and reopening the GUI?
jason_lightfootVL7B4
Try repaintview() or refreshview()
patryk_u2
I tried. It doesn't work.
When do you need the value updated - if it's just when you open the GUI then you can do that using OnPreOpen
patryk_u2
For example, when I have an open gui and check a checkbox in it or choose a value in combobox
Here's a working example using refreshview.
TrackerGUI.fsm
You can type the value for rangemax in the edit box and the tracker will scale accordingly.
