[ FlexSim 22.0.1 ]
I have a problem when zone is utilized with fluid tools. Let me explain the case first. There are two tanks "FluidTank1-2" that can send their liquid products to one of two lines "FluidToItem1-2" via one of two valves "FluidProcessor1-2". The lines are selected based on a label "Port". I added a "Zone" to make orders to be processed based on "Priority". Once I did that, FluidTank2 is keep sending liquid however, it was not selected by the processFlow. I found that the main reason that the FluidGenerator2 is keep sending to FluidTank2 and the latter is not closing its output port. When I removed the "Zone" from the processFlow, this problem was solved. I am so curious to know why this is happening. I am attaching both case; the one with the zone and the one without.
Best regards,
Mohamed
