Green and red input port symbol
martin_edviken
martin_edviken
[ FlexSim 16.0.1 ]
I wonder what this input port symbol means? I know that green means it's open and red is a closed port. But what does it mean when it's both green and red?
jeff_nordgren
When you see a green triangle symbol on the input or output port of an object, that means that FlexSim considers that port open. If you see a red triangle, then FlexSim considers that port closed. If either of the input or output ports has a red bar across the triangles (no matter the color of the triangle), that means that the natural order of opening/closing a port has been altered by code, using either the closeinput() or the closeoutput() commands.
