global table item creation
priyankasgoudar33
Message 1 of 9
priyankasgoudar33
[ FlexSim 20.0.10 ]
Hello I have a model where in source 1 I am creating two variant type parts. when part 1 that is var1 enters the processor. In both Queue2 and Queue3 part should be created following global table var1. and when var2 part enters in processor var2 global table should be followed to create item.
The item created in Queue should be pallet on part. for particular variant part particular item should be created.
variant.fsm
@Felix Möhlmann
Replies (8)
Message 2 of 9
FelixMoehlmann
As the item names and table names are equal, you can use the name to directly reference the table from which the data should be taken.
'Table(token.item.name)[row][col]'
I'm not sure what exactly you by 'particular item' that should be created, so in the attached model I just set the names of the created objects to the text in the tables.
If you want to actually create different flow item types, I would suggest to type in the rank of the respective item in the flow item bin into the table. This can then be read by the 'Create Objects' activity.
variant_fm.fsm
Message 3 of 9
priyankasgoudar33
Hi @Felix Möhlmann
If I have 20 Queue in my Model and 20 items(same process as above). Each buffer should be assigned to one particular item(Ex: P1_var1/P1_var2 should be assigned to Queue2 same as P2_var1/P2_var2 to Queue3 and so on). How can I do it
variant-fm.fsm
Message 4 of 9
FelixMoehlmann
I'd add an extra column to the tables, storing the information which queue the items should be moved to.
In addition, you can use the process flow block that creates the items as a subflow. This subflow can then run as many times as there are rows in the table, automatically scaling with the table size.
variant-fm2.fsm
Message 5 of 9
priyankasgoudar33
@Felix Möhlmann is the table name related to code?
Message 6 of 9
FelixMoehlmann
Yes, like I mentioned in the original answer. The items' names are used to refer to the table with the same name. (Item name is 'var1' -> read data from table 'var1')
Message 7 of 9
priyankasgoudar33
@Felix Möhlmann how can I do the same model without process flow just with coding can you help with this.
Message 8 of 9
jason_lightfoot_adsk
You need a loop and the commands createcopy and either moveobject or assign the '.up' attribute of the thing you want to move to the destination container.
eg:
item.up=newcontainer;
Message 9 of 9
kavika_faleumu
Hi @mary, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
