Getting error in object process flow while using list?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I am working on model where machine will take part from buffer and start process. Once buffer will be consumed, trigger will go to replenish buffer with respect to object. I am using list to pull part from buffer. But it seems there is something wrong in the flow.
Can you help me to identify the issue here?
@Jason Lightfoot
15.07.2022_Object_Process_Flow_Error.fsm
Thank you!
jason_lightfootVL7B4
You don't need token.Machine - just use current.
Also - I would use a subflow to push to the list and then when all are pulled the token will leave the RunSubflow activity and loop around.
15072022-object-process-flow-error_jl.fsm
rajankur6494
