Get a line of a custom code from a script
sebastien_b49
sebastien_b49
[ FlexSim 20.2.3 ]
Hi !
I'd like to write an automatic documentation system in my model. I added a Dashboard with Model documentation and within a dynamic flexscript I tried to recover one line from a custom code where the documentation is written.
I could recover the entire code but I did not succeed in separating it per line. It does not seem to take it as an array or a text, as the property length is not working. Neither is slice.
Is it possible to get one or several line from the codeNode property of a Custom Code ?
Test_Doc.fsm
regan_blackett
You will need to recast the code node's value as a string first then you perform whatever string based operations you need to do:
string codeNodeString = model().find("/Tools/ProcessFlow/ProcessFlow/Test>variables/codeNode").value.as(string);
This will get the code node as a string. Then something like this would let you get a portion of the code node as a substring:
string subString = codeNodeString.slice(codeNodeString.indexOf("Doc"));
I'm assuming the comment in your code node is what you were wanting shown on the dashboard.
jason_lightfootVL7B4
To answer your questions about multiple lines - here's an example using the split function to get an array
treenode codeNode = model().find("/Tools/ProcessFlow/ProcessFlow/Test>variables/codeNode");
string s=codeNode.value;
Array allLines=s.split(strascii(13));
for (int n=1;n<=allLines.length;n++)
      pt(allLines+"<br>");
You could also try replacing strascii(13) with <br> and then just print the string.
s=s.replace(strascii(13),"<br>",1);
print(s);
sebastien_b49
Thank you @Regan Blackett and @Jason Lightfoot !
I was missing the .as(string) in my code. I assumed the text returned with .value was enough.
