Gantt charts not shown in experimenter
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 20.1.2 ]
When you have a Gantt chart in your dashboard and you run the experimenter you won't see any saved graph. The only thing shown is a blank square.
Attached is a small example, but it is just a model with a Gantt chart.
Is there perhaps a work around for this for now?
GanttMissing.fsm
regan_blackett
@Patrick Zweekhorst
It looks like neither the Scenario chart nor the regular experiment results can currently work with the Gantt charts. So the work around, at least to get per-replication charts is to use a calculated table with a query like:
SELECT * FROM [Experiment].[State Gantt] WHERE Scenario = 1 AND Replication = 1
and then point a new chart at the calculated table.
patrick_zweekhorst
Hi @Regan Blackett
Thank you for the answer.
I will use the calculated table with that query for now.
JordanLJohnson
The fact that the Scenario chart doesn't work with the Gantt chart is by design. The fact that gantt chart isn't working in the experiment is a bug that we will fix.
Jordan Johnson
Principal Software Engineer
