- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 22.0.1 ]
Attached there is a image from a very simple model where I try to set the initial content for a FlowTank based on a global table. When setting value using Set flow content, content is updated as expected but the flow state of the tank stays as "Empty" because Initial Cont. for the tank's 3D object is set to 0. Setting this "Initial Cont." parameter directly from the table doesn't seem to be possible either.
So is there a way to set initial content in a way that would also update the state automatically, or is the best solution to just manually set the initial state at the same time when setting the content?
