Flexscript Error
Flexscript Error
samarth_v
Flexscript Error
samarth_v
[ FlexSim 19.1.1 ]
I was trying to modify the values for the arrival rates in my simulation but I was facing the following problems.
All i did was change the values of the existing model which was running smoothly.
Can anyone tell me why this issue is taking place?
Flexscript ErrorMODEL:/Tools/ProcessFlow/CurrentStateLogic/OTHER Live IB Empty>variables/arrivals/21/Quantity Line 1Not enough parameters in call to command bernoulli Flexscript ErrorMODEL:/Tools/ProcessFlow/CurrentStateLogic/OTHER Live IB Empty>variables/arrivals/21/QuantityCould not resolve correct operator for construct operation. Left side type is Variant&, right type is (invalid) Flexscript ErrorMODEL:/Tools/ProcessFlow/CurrentStateLogic/OTHER Live IB Empty>variables/arrivals/21/Quantity Could not finish parsing because of previous errors.
SCHamoen
@Samarth V The first is that in activity "OTHER Live IB Empty" a bernoulli function is called with not enough parameters. bernoulli needs at least 3 parameters. Most likely the 2 other Errors will also be fixed.
braydn_t
@Samarth V
Did Steven's answer work for you? If so, could you please click the accept button? If not could you let us know what else we can do to help you? Thanks!
