Flexscript error problem
joe_yee_w
joe_yee_w
[ FlexSim 21.1.4 ]
Hi there,
Does anyone know why the following error message shows when starting Flexsim?
chanykE2WUT
@Joe_yee W If you are opening a new model, you should not see such information as OEE is not default information in the software. You must be opening a pre-built model with OEE as part of the information in the statistic collector. Some info is missing there. Please check.
David
joe_yee_w
Hi David ,thank you for answering my question. Yes , i am opening a pre-bulit model. So which means that i required to refer back to the statistic collector to check the missing info?
chanykE2WUT
Yes. The software cannot access the value node under the Availability and OEE node.
joe_yee_w
Thanks for the info and really appreciate it!
