Find Item activity blocking the location
imasjc_
imasjc_
I have 1 object per storage location and I use Find Item so the task executer can go and load it. I have found a problem that sometimes when a TE is going to the location to load the object, another TE goes through the Find Item activity and is assigned the same location. Once it arrives it gets stuck because the previous one took it.
Is there any way to avoid assigning an item that has already been assigned to another TE?
Thanks!
FelixMoehlmann
As long as the item is marked as "outbound" (meaning its Storage.Item's 'assignedSlot' property is reset) it should not be found by any further storage system queries of Find Slot activities. Is the respective options checked in your model?
