Fetching Global Variable Value Using String Variable?
rajankur6494
Message 1 of 26
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I am using string variable to get global variable value. But it is writing variable name instead of value. What is the right way to do it?
GlobalVariableUsingStringVariable.fsm
Thank you!
Replies (25)
Message 21 of 26
rajankur6494
I will check and let you know if it works for me.
Message 22 of 26
rajankur6494
Hi @Jason Lightfoot,
I have multiple property belongs to 1 name. For Example: A_Table, A_Chair1, A_Chair2 etc.
How can I extract only "A" out of this (from the object in which labels are defined) to access global table like "A_GlobalTable" and similarly for other objects?
Message 23 of 26
jason_lightfootVL7B4
The letter 'A' must mean something real - floor id , area id or something so you'd put a label on called floor_id or something similar.
Maybe I'm too far away from the problem to see the value of what you're trying to do. I use object pointers not string paths as I find they're more powerful, and try to encourage people to do the same and write simple, generic code that scales. It's not for everyone I guess, but someone is usually paying for time, so it's good not to waste it.
Message 24 of 26
Matthew_Gillespie
@Ankur A3 I agree this looks like a much better approach. I would strongly suggest you use an object-based approach like what Jason is suggesting here. It will save you lots of headaches down the road.
Matthew Gillespie
FlexSim Software Developer
Message 25 of 26
rajankur6494
May be I am asking something very easy but I don't understand what do you mean by floor id here.
Can you help me to understand with example?
Thank you!
Message 26 of 26
You seem very attached to the name and to you the terms A, Chair and 2 are important form the name. I was mearly implying they must have some purpose which you are not sharing with us. I was just guessing and providing an example that you might be using them to interpret some grouping based on another attribute like 'Floor' or priority or whatever.
