Failure to login to SQL Server
chanykE2WUT
chanykE2WUT
[ FlexSim 23.1.3 ]
Hi
My customer is unable to log into SQL Server, anyone has any solution?
David
kavika_faleumu
@David Chan, what ODBC Driver version is your customer using? Here's a table of Supported Operating Systems and Driver Versions released by Microsoft.
julie_weller
Hi @David Chan,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
chanykE2WUT
@kavika
The customer uses Microsoft JDBC Driver 8.2.
Does it works?
David
jason_lightfoot_adsk
No - JDBC allows Java applications to connect to the database. FlexSim is not a Java application - use ODBC or native drivers.
