export data state of dashboard to Global Table
Tristan_Dionis
Tristan_Dionis
[ FlexSim 24.2.0 ]
Context :
I have a production line with a "STATE" indicator which collects for each machine on the line the percentage of time per category on the simulation
Example :
My objective is to retrieve this data in percentage by category and by machine in the form of a table to find the time corresponding to the breakdown of the line (Sum of breakdown times for each machine).
Problem :
In the settings of this indicator, in "Advanced" --> View Table
It is this result that I would like to retrieve in a Global Table and convert into time but I cannot display it in a Global Table.
Do you have an idea either to export this Table in a global Table or to simply recover the outage times with a Statistics collector for example ?
ClairAu
Maybe you could use a Composite State chart:
In the screenshot below, the breakdown time from the composite state chart is 442 seconds:
Which is actually the sum of the breakdown times of processors 1 and 2 (124 + 318).
ClairAu
I attach the sample model if needed.
2024-08-20 breakdown times.fsm
Tristan_Dionis
Good morning,
thank you for your response.
this solved my problem.
