Expertfit issue - the solution did not work
HKSim
HKSim
[ FlexSim 23.2.2 ]
Expertfit function doesn't work with a message "Not supported operation" error. I use Flexsim 2023 Update 2 version. I followed the solution suggested in another thread (register_OCX.bat), I have an error messages something like "RegSvr32.exe is not recognized as an internal or external command" how can I resolve this issue?
SimFlex_support
You should run the batch file as 'Administrater' user.
https://answers.flexsim.com/questions/120348/experfit-issue.html
Jeanette_Fullmer
Hi @HK, was David Seo's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
HKSim
Hi Jeanette,
Thanks for checking in. Yes, it worked well! I accepted the answer. Thank you.
HKSim
Thanks so much for pointing it out. I assumed I already ran it as "Administrator". The solution worked well!
