Experimenter Replications not completing
jbaah2
jbaah2
I have a model for an ED that I am trying to run in experimenter. However, the replications are not completing. I have tried several times but I get errors (attached). I have previously run the experimenter for 3 months with 7 days warmup and 15 replications. This worked. However, attempts to run the model in experimenter for 6 months with 7 days warmup and 10 replications are not working and give the errors attached.
I have updated the software to the current version however, the problem still occurs.
Suggested solutions to similar compliants on the flexsim forum platform seems to be that the model should be run on RAM. I will be glad if you could recommend the computer capacity requirement to effectively and efficiently run the model in experimenter with no issues.
I will be glad with any form of support.
Thank you
joerg_vogel_HsH
Try first to restrict the number of used cores on advanced tab of experiment. Yes, running multiple experiments depends on system memory amount. You can easily estimate this by running a single run and check resource utilization in task manager. Roughly you need this resource capacity for each running experiment in parallel. There also limits if you have connected your model to outside resources like python or plc.
