exception: FlexScript exception: VIEW:/nodefunctions/workspace/openworkspace
tejas_g
Message 1 of 8
tejas_g
[ FlexSim 19.1.2 ]
I am using Flexsim 19.1.0 ,
whenever I am opening my open I am getting this exception message :
"exception: FlexScript exception: VIEW:/nodefunctions/workspace/openworkspace"
And my model gets hang when I try to do "Open Default workplace", then I have to manually force close the model.
How to solve this issue?
Replies (7)
Message 2 of 8
tanner_p
@TEJAS G,
Do you get this exception any time you open FlexSim or only for a particular model? If it's a particular model, perhaps you could upload it so we can look at it?
Additionally, others have had similar errors in the past. You might want to review the answer from this post and try some of the potential solutions for ridding the model of the error.
Message 3 of 8
m_rosadini
@tanner.p We are experiencing the same issue in two models at this time. We get this error and if you try Open defaut Workspace it will crash.
I can share the models via private
Message 4 of 8
tanner_p
@marcello.rosadini,
I will email you and you can reply with the models so I can look at them. This may be beyond my understanding, but I'll give it a shot!
Message 5 of 8
tanner_p
We fixed Marcello's model through email.
To solve this issue:
1) Run the code provided below in a Script window:
treenode activeViews = node("VIEW:/active");
treenode backPanel = node("VIEW:/active/MainPanel/BackPanel");
while (content(activeViews) > 1)  {
  destroyobject(last(activeViews));
clearcontents(backPanel);
2) Select View -> Open Default Workspace
This should fix the model and prevent it from crashing.
Message 6 of 8
aldo_c3
where is the script window in flexim?
Message 7 of 8
jason_lightfoot_adsk
You can click on this button to open it: 36767-1613176609115.png
or open it from the Debug menu:
Message 8 of 8
Ben_WilsonADSK
The the Script Console does require a license. See the article FlexSim Feature Limitations by License Type.
