Event triggered source inconsistent behavior
sudheer_r
sudheer_r
[ FlexSim 23.2.0 ]
In below image event triggered source has triggered two tokens for ACR
ACR_BatteryCharging.fsm
In below image event triggered source has triggered only token for ACR
ACR_BatteryCharging_1.fsm
Only difference in both instances is ACR1 and ACR2 are included in the first image model and in the second image model only ACR is attached.
There I see inconsistent event triggers for same ACR.
Any reason for this kind of behavior.
jason_lightfootVL7B4
If I set a stop time of 23.43 seconds and run with 1 or 3 ACRs attached the results are the same - one token in the custom code activity for the object named "ACR". Please provide complete steps to reproduce this. (note: macros in match-value fields seem to work fine - I've seen issues in the past...)
sudheer_r
Instead of placing stop time at 23.43 seconds, Just manually press the stop button while clock is around 21 Seconds and then place stop time around 23.43 seconds. I have seen the same behavior which I was mentioning.
If makes no difference to me - I see the same behavior. Make sure you're running the latest version of FlexSim.
Make sure the model you uploads is the correct one for the issue to occur. (Also I'd remove one model - you don't need to upload both).
Hi @SudheerReddy, was our answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
