[ FlexSim 18.0.3 ]
We have a model where we are using the following syntax to fetch Global Table values:
int value = Table("tableName")["row_name"]["col_name"];Some of the cells in the table are numbers assigned as numeric data, while others are distributions that are assigned as FlexScript data. This works very well as it evaluates the distribution similar to executetablecell, and is much faster than our previous row and column lookup code.
The issue we are having is when we import table information via MTEI, it changes the cells that are assigned as FlexScript to string data, which prevents the code above from evaluating the distribution. Is there a way to preserve how the cells are assigned to keep them set as FlexScript, or is there some code I can run after the MTEI import that would set each of the string cells to be FlexScript data type instead? Alternatively, if the value is stuck as a string as a result of the MTEI import, is there a "dot syntax" way to perform a type conversion to execute the contents of a string cell (like how executetablecell works)?
@Matthew Gillespie, I've seen you reply to these kinds of questions before so I am tagging you in the hopes that you can help. Thanks in advance!
