Change a Marks
Change a Marks
jean_baptiste_g
Change a Marks
jean_baptiste_g
[ FlexSim 18.0.3 ]
Hi all,
I need to change the Marks of a Tank depending in wich case I'm. If I want a Mid Mark = 12000L, 12000 is stored in a label. I know how to sample this value, but I can't sample the location of the Mid Mark, I only can sample the value of the Mid Mark. How can I do that ?
Thank you in advance for your answer.
clair_augsburgerZGWRZ
Hello Jean-Baptiste,
I wonder from which field are you using the sampler. In the screenshot below I used the sampler from a script window and it provides several options:
getvarnum(model().find("FluidTank1"), "midmark") will return the value of the Mid Mark.
getvarnode(model().find("FluidTank1"), "midmark") will return the node where the Mid Mark is stored.
model().find("FluidTank1>variables/midmark") will also return the node where the Mid Mark is stored.
axel_kohonen
Hi @Jean-Baptiste G
As Clair A suggests, use the sampler, but if you want to set the value instead of get it then use
setvarnum(...) instead of getvarnum(...)
