Error when building conveyors
layan_ag
layan_ag
[ FlexSim 22.2.1 ]
I am just building conveyors and this error suddenly comes and all conveyors disappear I have to repeat everything again why does this occur?screenshot-620.png and what should I do when this happens?
jason_lightfoot_adsk
The quickest option will probably be to revert to a saved earlier version of the model.
Do you know what actions you were performing in order for us to recreate the issue?
layan_ag
I just pressed control+z
kavika_faleumu
Hey @len zm, as Jason suggested, reverting back to an earlier version of your model is the best course of action in this case. You can sometimes achieve temporary control of your model again if you go into the Tree and delete the ConveyorSystem. Then you can see your model again, but errors may still be present. Ben points out in a post he made a while back some key ways to mitigate file corruption when it happens. I suggest saving iterations of your file with Auto Increment Save (or Ctrl + Shift + S). That way you have different iterations of your model you can revert back to if you run into this problem in the future.
Furthermore, avoid using Ctrl + Z or undo when working with Conveyors. There are some bugs the devs are aware of when dealing with undoing changes on Conveyors.
Jeanette_Fullmer
Hi @len zm, was Kavika F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
