Error process flow for dispatching
ismael_r3
ismael_r3
[ FlexSim 21.0.0 ]
Hello, I have tried in my process flow to restrict the spaces where my picking orders should go, but in general when picking area 1 and 2 are filled, my process flow throws an error, because it cannot leave the order in its place. I wanted if you could modify my process flow so that if there is no space, I do not do the order, I do not know where to place it, and I tried some, use a decide before the token arrives, but it does not work, I am new using process flow, you could correct the error in my process flow, I appreciate it! 35517-1608391718287.png
35543-1608392143587.pngèxperimenter.fsmI attached the model
gokulakrishnan_k2
@Ismael R3 Hi! I had a look into your model i assume you want to pull item based on the order created in the scheduled source at particular time from the floor storage. For that you have created the initial inventory.
If you want to pull item based on the order you should have created that item with label and all schedule should have created with label to identify item floor for the pull action (label would be an easy option). Based on the order arrival you assign slot using find & assign slot options. you can refer tutorial for assign slot option
jason_lightfootVL7B4
Hi @Ismael R3, was Gokulakrishnan Kandasamy's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
