[ FlexSim 21.0.0 ]
Hi I have some questions on the drive in or thru rack object in the FlexSim warehouse module.
1. Increase the number of vertical beam in the y direction with a certain width? Currently when the sy of the rack is increase, the number of vertical beam will increase accordingly with a certain width. Is there a way for user to fix it?
2. How to fix the number of pallets in the y-direction? Is there any possibility by increasing the slot padding to keep a distance between the pallets so that a certain number of pallet on one level in a single bay can be controlled?
3. How to placing the pallets from top down instead bottom up? By default, the pallets are placed bottom up, but this is not the default item placement sequence for drive-in or thru rack. Once the bottom is filled, the forklift cannot go in anymore. Can the Start level with Z- be used for such arrangement? Or is there any way?
Thanks for looking these questions.
Regards
David
