Error occurred while exporting data from the FlexSim global table to the MySQL database
supportPHJ4A
Message 1 of 1
supportPHJ4A
We encountered a problem when using the 2024.0.7 version of the database connector:
The connection to the database and the data import are both normal, but when exporting the global table of FlexSim to the table in the MySQL database, it is impossible to select the corresponding table and fields.
I found the method mentioned in the posts about similar issues, but it couldn't solve my problem well and resulted in the following error as shown in the picture.
The links to the posts about similar issues are as follows:
Solved: Export a Global Table from FlexSim to BaseDate MySQL - Autodesk Community
What should I do to correctly export the data? My MySQL version is 8.0.46. If you have any solutions or ideas, please let me know. Thank you very much.
Replies (0)
